[GRASSLIST:9442] Re: Problem installing gdal-grass-1.3.1
Maik Trömel
maik.troemel at maitro.net
Tue Dec 13 09:49:54 EST 2005
I had a look on the "Makefile"
Line 49:
GLIBNAME = gdal_GRASS.so
OLIBNAME = ogr_GRASS.so
default: $(GLIBNAME) $(OLIBNAME)
install: default
install -d $(AUTOLOAD_DIR)
cp $(GLIBNAME) $(AUTOLOAD_DIR)
cp $(OLIBNAME) $(AUTOLOAD_DIR)
The error occures when trying to copy gdal_GRASS.so to $(AUTOLOAD_DIR).
I can't find gdal_GRASS.so . But why isn't it where it should be. Where
should I find this file? Is it from gdal_grass-package or from another
package? Where is it initialised?
Anybody an idea?
Greetings
Maik
Maik Trömel wrote:
> Thanks for your support,
> Line 49:
> install: default
> Where should I find this file? Is it from gdal_grass-package or from
> another package? Where is it initialised?
> Anybody an idea?
> Greetings
> Maik
>> Hamish wrote:
>>>> installing GRASS-6.0.1 from tar.gz I got a problem with
>>>> gdal-grass-1.3.1.
>>> To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug in
>>> 1.3.1 release)
>>> http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz
>> I tried it: Same problem.
>>> Hamish
>> Hernán De Angelis wrote:
>>> Maik,
>>> Are your GRASS and GDAL in standard directories? If not, if you only
>>> did
>>> ./configure
>>> without specifying
>>> --with-grass=/your/path/to/grass/
>>> and
>>> --with-gdal=/your/path/to/gdal/bin/gdal-config
>> I ran it this way. I think thats not the problem.
>>> it will never work. In that case you might also need to make the
>>> libraries accesible in /etc/ld.so.conf (and run "ldconfig" as root
>>> after that)
>> I have updated /etc/ld.so.conf and run ldconfig. It has no influence
>> on the problem.
>>> Hope this helps
>>> Hernán
>>> El Lunes 12 Diciembre 2005 11.13, Maik Trömel escribió:
>>>> Hello GRASS-Users,
>>>> gdal-grass-1.3.1.
>>>> I run:
>>>> ./configure -> no problem
>>>> make -> no problem
>>>> make install (as root):
>>>>> install -d /usr/lib/gdalplugins
>>>>> cp gdal_GRASS.so /usr/lib/gdalplugins
>>>>> cp: cannot stat `gdal_GRASS.so': No such file or directory
>>>>> make: *** [install] Error 1
>>>> Anybody an idea what the problem could be?
>>>> Thanks for help!
>>>> Maik
>>> gdal-grass-1.3.1.
>> 1.3.1 release)
>> Hamish
>> Maik,
>> Are your GRASS and GDAL in standard directories? If not, if you only did
>> ./configure
>> without specifying
>> and
>> after that)
> on the problem.
>> Hope this helps
>> Hernán
>>> Hello GRASS-Users,
>>> gdal-grass-1.3.1.
>>> I run:
>>> make -> no problem
>>> Thanks for help!
>>> Maik
