[GRASSLIST:9445] Re: Problem installing gdal-grass-1.3.1
Hernán De Angelis
hernan.deangelis at glocalnet.net
Tue Dec 13 12:34:24 EST 2005
Maik,
I did my installation last weekend. I did the following configure:
./configure --prefix=/usr/local/gdal-grass-1.3.1
--with-gdal=/usr/local/gdal/bin/gdal-config
--with-grass=/usr/local/grass-6.1.0/grass-6.1.cvs
and everything went smoothly. In my box, these two files were installed in:
/usr/local/gdal-1.3.1/lib/gdalplugins
I am not an expert but I guess that in your case something was left from a
previous failed attempt to install. I think it would be a good idea to do a
"make distclean" on the source directory of gdal-grass and start a new build.
Good luck!
Hernán
El Martes 13 Diciembre 2005 15.49, Maik Trömel escribió:
> I had a look on the "Makefile"
> Line 49:
> GLIBNAME = gdal_GRASS.so
> OLIBNAME = ogr_GRASS.so
> default: $(GLIBNAME) $(OLIBNAME)
> install: default
> install -d $(AUTOLOAD_DIR)
> cp $(GLIBNAME) $(AUTOLOAD_DIR)
> cp $(OLIBNAME) $(AUTOLOAD_DIR)
> The error occures when trying to copy gdal_GRASS.so to $(AUTOLOAD_DIR).
> I can't find gdal_GRASS.so . But why isn't it where it should be. Where
> should I find this file? Is it from gdal_grass-package or from another
> package? Where is it initialised?
> Anybody an idea?
> Greetings
> Maik
> Maik Trömel wrote:
> > Thanks for your support,
> > Line 49:
> > install: default
> > Where should I find this file? Is it from gdal_grass-package or from
> > another package? Where is it initialised?
> > Anybody an idea?
> > Greetings
> > Maik
> >> Hamish wrote:
> >>>> installing GRASS-6.0.1 from tar.gz I got a problem with
> >>>> gdal-grass-1.3.1.
> >>> To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug in
> >>> 1.3.1 release)
> >>> http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz
> >> I tried it: Same problem.
> >>> Hamish
> >> Hernán De Angelis wrote:
> >>> Maik,
> >>> Are your GRASS and GDAL in standard directories? If not, if you only
> >>> did
> >>> ./configure
> >>> without specifying
> >>> --with-grass=/your/path/to/grass/
> >>> and
> >>> --with-gdal=/your/path/to/gdal/bin/gdal-config
> >> I ran it this way. I think thats not the problem.
> >>> it will never work. In that case you might also need to make the
> >>> libraries accesible in /etc/ld.so.conf (and run "ldconfig" as root
> >>> after that)
> >> I have updated /etc/ld.so.conf and run ldconfig. It has no influence
> >> on the problem.
> >>> Hope this helps
> >>> Hernán
> >>> El Lunes 12 Diciembre 2005 11.13, Maik Trömel escribió:
> >>>> Hello GRASS-Users,
> >>>> gdal-grass-1.3.1.
> >>>> I run:
> >>>> ./configure -> no problem
> >>>> make -> no problem
> >>>> make install (as root):
> >>>>> install -d /usr/lib/gdalplugins
> >>>>> cp gdal_GRASS.so /usr/lib/gdalplugins
> >>>>> cp: cannot stat `gdal_GRASS.so': No such file or directory
> >>>>> make: *** [install] Error 1
> >>>> Anybody an idea what the problem could be?
> >>>> Thanks for help!
> >>>> Maik
> >>> gdal-grass-1.3.1.
> >> 1.3.1 release)
> >> Hamish
> >> Maik,
> >> Are your GRASS and GDAL in standard directories? If not, if you only did
> >> ./configure
> >> without specifying
> >> and
> >> after that)
> > on the problem.
> >> Hope this helps
> >> Hernán
> >>> Hello GRASS-Users,
> >>> gdal-grass-1.3.1.
> >>> I run:
> >>> make -> no problem
> >>> Thanks for help!
> >>> Maik
Hernán De Angelis
