[GRASSLIST:9447] Re: Problem installing gdal-grass-1.3.1
    Luca Casagrande
    luca.casagrande at gmail.com
    Tue Dec 13 14:40:57 EST 2005
Alle 17:34, martedì 13 dicembre 2005, Hernán De Angelis ha scritto:
> Maik,
> I did my installation last weekend. I did the following configure:
> ./configure --prefix=/usr/local/gdal-grass-1.3.1
> --with-gdal=/usr/local/gdal/bin/gdal-config
> --with-grass=/usr/local/grass-6.1.0/grass-6.1.cvs
> and everything went smoothly. In my box, these two files were installed in:
> /usr/local/gdal-1.3.1/lib/gdalplugins
> I am not an expert but I guess that in your case something was left from a
> previous failed attempt to install. I think it would be a good idea to do a
> "make distclean" on the source directory of gdal-grass and start a new
> build.
> Good luck!
> Hernán
> El Martes 13 Diciembre 2005 15.49, Maik Trömel escribió:
> > I had a look on the "Makefile"
> > Line 49:
> > GLIBNAME =      gdal_GRASS.so
> > OLIBNAME =      ogr_GRASS.so
> > default:        $(GLIBNAME) $(OLIBNAME)
> > install:        default
> >        install -d $(AUTOLOAD_DIR)
> >        cp $(GLIBNAME) $(AUTOLOAD_DIR)
> >        cp $(OLIBNAME) $(AUTOLOAD_DIR)
> > The error occures when trying to copy gdal_GRASS.so to $(AUTOLOAD_DIR).
> > I can't find gdal_GRASS.so . But why isn't it where it should be. Where
> > should I find this file? Is it from gdal_grass-package or from another
> > package? Where is it initialised?
> > Anybody an idea?
> > Greetings
> > Maik
> > Maik Trömel wrote:
> > > Thanks for your support,
> > > Line 49:
> > > install:        default
> > > Where should I find this file? Is it from gdal_grass-package or from
> > > another package? Where is it initialised?
> > > Anybody an idea?
> > > Greetings
> > > Maik
> > >> Hamish wrote:
> > >>>> installing GRASS-6.0.1 from tar.gz I got a problem with
> > >>>> gdal-grass-1.3.1.
> > >>> To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug
> > >>> in 1.3.1 release)
> > >>> http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz
> > >> I tried it: Same problem.
> > >>> Hamish
> > >> Hernán De Angelis wrote:
> > >>> Maik,
> > >>> Are your GRASS and GDAL in standard directories? If not, if you only
> > >>> did
> > >>> ./configure
> > >>> without specifying
> > >>> --with-grass=/your/path/to/grass/
> > >>> and
> > >>> --with-gdal=/your/path/to/gdal/bin/gdal-config
> > >> I ran it this way. I think thats not the problem.
> > >>> it will never work. In that case you might also need to make the
> > >>> libraries accesible in /etc/ld.so.conf (and run "ldconfig" as root
> > >>> after that)
> > >> I have updated /etc/ld.so.conf and run ldconfig. It has no influence
> > >> on the problem.
> > >>> Hope this helps
> > >>> Hernán
> > >>> El Lunes 12 Diciembre 2005 11.13, Maik Trömel escribió:
> > >>>> Hello GRASS-Users,
> > >>>> gdal-grass-1.3.1.
> > >>>> I run:
> > >>>> ./configure  -> no problem
> > >>>> make -> no problem
> > >>>> make install (as root):
> > >>>>> install -d /usr/lib/gdalplugins
> > >>>>> cp gdal_GRASS.so /usr/lib/gdalplugins
> > >>>>> cp: cannot stat `gdal_GRASS.so': No such file or directory
> > >>>>> make: *** [install] Error 1
> > >>>> Anybody an idea what the problem could be?
> > >>>> Thanks for help!
> > >>>> Maik
> > >>> gdal-grass-1.3.1.
> > >> To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug in
> > >> 1.3.1 release)
> > >> Hamish
> > >> Maik,
> > >> did ./configure
> > >> without specifying
> > >> and
> > >> after that)
> > > on the problem.
> > >> Hope this helps
> > >> Hernán
> > >>> Hello GRASS-Users,
> > >>> gdal-grass-1.3.1.
> > >>> I run:
> > >>> make -> no problem
> > >>> Thanks for help!
> > >>> Maik
I tryed with your same configure and after a DEEP clean, but the error it's
the same...
Thx
Luca
"Esperienza è il nome che ciascuno da ai suoi errori. (O. Wilde) "
GENTOO-GIS Development Team
jabber: casagrande at jabber.linux.it
