[GRASSLIST:9584] Re: Problem installing gdal-grass-1.3.1
    Maik Trömel
    maik.troemel at maitro.net
    Tue Dec 20 04:35:11 EST 2005
I found the "gdal-GRASS.so"-file. It's in "/usr/local/lib". I changed
the filename in the Makefile
"GLIBNAME = gdal_GRASS.so" to "GLIBNAME= /usr/local/lib/gdal_GRASS.so"
The error
install -d /usr/local/lib/gdalplugins
cp gdal_GRASS.so /usr/local/lib/gdalplugins
cp: cannot stat `gdal_GRASS.so': No such file or directory
make: *** [install] Error 1
doesn't occure any longer. But therefore I get the same error with the
next file "ogr_GRASS.so":
cp /usr/local/lib/gdal_GRASS.so /usr/local/lib/gdalplugins
cp /usr/local/lib/ogr_GRASS.so /usr/local/lib/gdalplugins
cp: cannot stat `ogr_GRASS.so': No such file or directory
make: *** [install] Fehler 1
But again I can't find the file.
Probably someone has an idea.
Greetings Maik
Luca Casagrande wrote:
>Alle 17:34, martedì 13 dicembre 2005, Hernán De Angelis ha scritto:
>>Maik,
>>I did my installation last weekend. I did the following configure:
>>./configure --prefix=/usr/local/gdal-grass-1.3.1
>>--with-gdal=/usr/local/gdal/bin/gdal-config
>>--with-grass=/usr/local/grass-6.1.0/grass-6.1.cvs
>>and everything went smoothly. In my box, these two files were installed in:
>>/usr/local/gdal-1.3.1/lib/gdalplugins
>>I am not an expert but I guess that in your case something was left from a
>>previous failed attempt to install. I think it would be a good idea to do a
>>"make distclean" on the source directory of gdal-grass and start a new
>>build.
>>Good luck!
>>Hernán
>>El Martes 13 Diciembre 2005 15.49, Maik Trömel escribió:
>>>I had a look on the "Makefile"
>>>Line 49:
>>>OLIBNAME =      ogr_GRASS.so
>>>default:        $(GLIBNAME) $(OLIBNAME)
>>>install:        default
>>>       install -d $(AUTOLOAD_DIR)
>>>       cp $(GLIBNAME) $(AUTOLOAD_DIR)
>>>       cp $(OLIBNAME) $(AUTOLOAD_DIR)
>>>The error occures when trying to copy gdal_GRASS.so to $(AUTOLOAD_DIR).
>>>I can't find gdal_GRASS.so . But why isn't it where it should be. Where
>>>should I find this file? Is it from gdal_grass-package or from another
>>>package? Where is it initialised?
>>>Anybody an idea?
>>>Greetings
>>>Maik
>>>Maik Trömel wrote:
>>>>Thanks for your support,
>>>>Line 49:
>>>>install:        default
>>>>Where should I find this file? Is it from gdal_grass-package or from
>>>>another package? Where is it initialised?
>>>>Anybody an idea?
>>>>Greetings
>>>>Maik
>>>>>Hamish wrote:
>>>>>>>installing GRASS-6.0.1 from tar.gz I got a problem with
>>>>>>>gdal-grass-1.3.1.
>>>>>>To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug
>>>>>>in 1.3.1 release)
>>>>>>http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz
>>>>>I tried it: Same problem.
>>>>>>Hamish
>>>>>Hernán De Angelis wrote:
>>>>>>Maik,
>>>>>>Are your GRASS and GDAL in standard directories? If not, if you only
>>>>>>did
>>>>>>./configure
>>>>>>without specifying
>>>>>>--with-grass=/your/path/to/grass/
>>>>>>and
>>>>>>--with-gdal=/your/path/to/gdal/bin/gdal-config
>>>>>I ran it this way. I think thats not the problem.
>>>>>>it will never work. In that case you might also need to make the
>>>>>>libraries accesible in /etc/ld.so.conf (and run "ldconfig" as root
>>>>>>after that)
>>>>>I have updated /etc/ld.so.conf and run ldconfig. It has no influence
>>>>>on the problem.
>>>>>>Hope this helps
>>>>>>Hernán
>>>>>>El Lunes 12 Diciembre 2005 11.13, Maik Trömel escribió:
>>>>>>>Hello GRASS-Users,
>>>>>>>gdal-grass-1.3.1.
>>>>>>>I run:
>>>>>>>./configure  -> no problem
>>>>>>>make -> no problem
>>>>>>>make install (as root):
>>>>>>>>install -d /usr/lib/gdalplugins
>>>>>>>>cp gdal_GRASS.so /usr/lib/gdalplugins
>>>>>>>Anybody an idea what the problem could be?
>>>>>>>Thanks for help!
>>>>>>>Maik
>>>>>>gdal-grass-1.3.1.
>>>>>To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug in
>>>>>1.3.1 release)
>>>>>Hamish
>>>>>Maik,
>>>>>did ./configure
>>>>>without specifying
>>>>>and
>>>>>after that)
>>>>on the problem.
>>>>>Hope this helps
>>>>>Hernán
>>>>>>Hello GRASS-Users,
>>>>>>gdal-grass-1.3.1.
>>>>>>I run:
>>>>>>make -> no problem
>>>>>>Thanks for help!
>>>>>>Maik
>I tryed with your same configure and after a DEEP clean, but the error it's
>the same...
>Thx
>Luca
