[GRASSLIST:9488] v.in.ascii malloc error in 6.1cvs
Ian MacMillan
Ian.MacMillan at pomona.edu
Wed Dec 14 20:11:44 EST 2005
Has anyone found out why malloc errors are appearing using v.in.ascii
with Lorenzo's binaries? I can't import any ascii files using 6.1cvs
anymore, I have to revert back to 6.0. The exact same commands that
produce an error like:
*** malloc[9282]: Deallocation of a pointer not malloced: 0x501740;
This could be a double free(), or free() called with the middle of an
allocated block; Try setting environment variable MallocHelp to see
tools to help debug
tools to help debug
tools to help debug
*** malloc[9282]: error for object 0x501740: Incorrect checksum for
freed object - object was probably modified after being freed; break at
szone_error
Segmentation fault
work using 6.0. I have run into this problem intermittently since
early October, and have seen it mentioned a few other times on this
list since then.
Any ideas?
Thanks for your time,
Ian
This message has been scanned by Postini anti-virus software.
