[GRASSLIST:9499] Re: v.to.rast problem
Hamish
hamish_nospam at yahoo.com
Thu Dec 15 05:54:18 EST 2005
> >>v.to.rast input=jgenel1 layer=1 output=jgenel1 use=attr column=yas
> >>rows=4096
> >>Loading vector information ...ERROR: Column type not supported by
> >>db_select_to_array()
> v.info -c jgenel1
> Displaying column type for database connection of layer 1:
> INTEGER|cat
> CHARACTER|yas
> INTEGER|count
> DOUBLE PRECISION|sum_cat
> in postgresql
> bzk=# \d jgenel1
> Table "public.jgenel1"
> Column | Type | Modifiers
> cat | integer |
> yas | character varying(80) |
> count | integer |
> sum_cat | double precision |
The v.to.rast column= must be numeric (integer, double).
(ok, poorly documented & error message might make a suggestion)
Alternately if you really want to save the labels, use the cat column
for the value and then make a "$MAPSET/cats/" file with the cat numbers
and the text labels. This would be pretty easy to generate
automatically. I am not sure if/where this is mentioned in the modern
documentation. Should probably be in grass6/raster/rasterintro.html or
a grass6/doc/raster/specification.html ? Doxygen?
Hamish
