[GRASSLIST:9543] Re: rectifying images
    Hamish
    hamish_nospam at yahoo.com
    Fri Dec 16 08:22:56 EST 2005
> I need to rectify several images in the next time. Is there a way to
> automatize this procedure a little bit? I have the "original" image and
> then about 10 to 20 images which needs to be corrected that they refer
> to the original one. I thought of something like saving the correction
> points of the original image to an file, so that I don't need to mark
> again (the reference points will be the same for all images) and I only
> need to specify them in the images which needs to be rectified.
Add all the images to a group, then rectify the lot.
i.group input=name[,name,...]
i.rectify -a
Hamish
