[GRASSLIST:9545] Re: rectifying images
Wolfgang Zillig wolfgang.zillig at web.de
Fri Dec 16 09:13:03 EST 2005
I'm not sure if this helps for my problem (perhaps I was not clear
enough in my description). The problem is, that I have one original
images which I want to use as reference and all others are more or less
deformed but no one at the same level. So I think I will have mark my
reference points in all deformed images. When I understand right
grouping is good, when you have many images whith the same deformation,
or am I wrong?
Wolfgang
Hamish schrieb:
>>I need to rectify several images in the next time. Is there a way to
>>automatize this procedure a little bit? I have the "original" image and
>>then about 10 to 20 images which needs to be corrected that they refer
>>to the original one. I thought of something like saving the correction
>>points of the original image to an file, so that I don't need to mark
>>again (the reference points will be the same for all images) and I only
>>need to specify them in the images which needs to be rectified.
>Add all the images to a group, then rectify the lot.
>i.group input=name[,name,...]
>i.rectify -a
>Hamish
