[GRASSLIST:9567] Re: Global topography
Joel Peter William Pitt
joel.pitt at gmail.com
Mon Dec 19 01:01:20 EST 2005
Here is the HDR fiel I forgot to attach.
On 12/19/05, Joel Peter William Pitt <joel.pitt at gmail.com> wrote:
> Hi all,
> I'm trying to georeference the global topography data here:
> ftp://topex.ucsd.edu/pub/global_topo_2min
> WIth more info here:
> http://topex.ucsd.edu/WWW_html/mar_topo.html
> It comes with hdr and ers files (attached) but GRASS opens the img
> data as unprojected.
> I've tried setting the projection and datum manually and then
> importing but I'm just getting myself horribly confused.
> I managed to find a file online that defined the MRWORLD projection as:
> MRWORLD:PROJCS["MRWORLD",PROJECTION["Mercator_1SP"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",0],PARAMETER["scale_factor",1],PARAMETER["false_easting",0],PARAMETER["false_northing",20000000]]
> I also tried manually setting the cell header as per the conversions
> in the GRASSLIST post here:
> http://lists.directionsmag.com/discussion/read.php?f=16&i=1388&loc=0&t=1388
> Can anyone help me?
> Alternatively, if there is a global topography (including sea floor)
> dataset which is more easily included with correct projection and
> datum then feel free to point me to that.
> Much thanks,
> Joel
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20051219/9b0209f2/topo_8.2.obj
