[GRASSLIST:9569] Re: still dbf - v.in.ascii import
Francesco Mirabella
mirabell at unipg.it
Mon Dec 19 04:00:58 EST 2005
Thanks Hamish and list,
that worked, I previously tried INT4, thinking that it was the same, but
it is not.
Now it looks ok
cheers,
Francesco
On Sat, Dec 17, 2005 at 12:25:55AM +1300, Hamish wrote:
> > I found the same problem described below, can someone say if and how
> > it was solved?
> > > > I have a problem with importing ascii points into grass:
> > > > I need to import a vector ascii map into grass, grass is connected
> > > > to a .dbf database. Following the manpage, it seems that the
> > > > v.in.ascii command is the same whatever is the database I want to
> > > > connect to, so I type:
> > > > v.in.ascii input=ascii_file.txt output=prova_dbf fs=tab
> > > > columns='cat integer, x double precision, y double precision,
> > > > cdp_number varchar(20), line_name varchar(20), acquisition_year
> > > > varchar(20)' x=2 y=3 cat=1
> > > > but I get:
> > > > DBMI-DBF driver error:
> > > > Incompatible value type.
> > > > Error in db_execute_immediate()
> > > > ERROR: Cannot insert values: insert into prova_ar_dbf values ( 1,
> > > > 11.919589, 43.679116, 101, 'ar315', 1981)
> > > I think that cdp_number and acquisition_year are of integer type,
> > > not varchar. At least they are not quoted.
> try:
> v.in.ascii input=ascii_file.txt output=prova_dbf fs=tab x=2 y=3 cat=1 \
> columns='cat integer, x double, y double, cdp_number integer, line_name varchar(20), acquisition_year integer'
> i.e. change varchar() to integer in the integer only columns. I had
> thought that Radim had modified v.in.ascii to let column types defined
> in columns= override what was scanned. Maybe not, or maybe this is only
> in the 6.1 development branch.
> Hamish
Francesco Mirabella,
Structural Geology and Geophysics
address: University of Perugia,
Dipartimento di Scienze della Terra
Piazza Universita', 1 06100 Perugia (Italy)
tel: ++39.(0)75.585 2651
fax: ++39.(0)75.585 2603
e-mail: mirabell at unipg.it
web: http://www.unipg.it/~mirabell/
