[GRASSLIST:9578] Re: script for creating map
    Luigi Ponti
    lponti at infinito.it
    Mon Dec 19 13:05:40 EST 2005
The following script works when called from the command line of GRASS
6.0.0 running under cygwin on windows NT. It saves the x0 monitor to a
.png file.
Ciao,
Luigi
----script begins----
#!/bin/bash
d.mon start=x0
d.vect map=vectorName
d.out.png output=mapName
d.mon stop=x0
----script ends------
Maik Trömel wrote:
> When I try to run "d.mon start=PNG" the error doesn't occure. But there
> is another error:
> after running
> d.mon start=PNG
> d.mon select=PNG
> d.rast geom_summe_s_filt_country
> d.vect map=grass_country
> d.mon stop=PNG
> PNG: GRASS_TRUECOLOR status: FALSE
> PNG: collecting to file: map.png,
>    GRASS_WIDTH=640, GRASS_HEIGHT=480
> Graphics driver [PNG] started
> 100%
> Monitor 'PNG' terminated
> ERROR - eof from graphics monitor.
> Maik
> Maik Trömel wrote:
>> I tried it out. The problem is, that its not possible to start a display.
>> When I run "d.mon start=x0" I get an error:
>> ERROR: Graph_Set: can't open Display
>> No socket to connect to for monitor <x0>.
>> Problem selecting x0. Will try once more
>> Any idea what the problem could be?
>> Maik
>> Michael Barton wrote:
>>> Check out the d.out.file script (or it's predecessor, d.out.png) that I
>>> wrote and is included with GRASS. This will export whatever is on the
>>> current monitor to a png (or other formats if you have gdal). Add
>>> d.mon and
>>> d.rast and/or d.vect and you can script the creation of a map and its
>>> export
>>> to png.
>>> Michael
>>> ______________________________
>>> Michael Barton, Professor of Anthropology
>>> School of Human Evolution and Social Change
>>> Arizona State University
>>> Tempe, AZ  85287-2402
>>> USA
>>> voice: 480-965-6262; fax: 480-965-7671
>>> www: http://www.public.asu.edu/~cmbarton
>>>> From: Maik Trömel <maik.troemel at maitro.net>
>>>> Date: Thu, 15 Dec 2005 11:28:48 +0100
>>>> To: GRASSLIST <GRASSLIST at baylor.edu>
>>>> Subject: [GRASSLIST:9498] script for creating map
>>>> Hello Grass-Users,
>>>> I want to write a script that creates a map as a png-file. I know
>>>> how to
>>>> make it by hand. But when I try to script it, it doesn't work because I
>>>> can't open a monitor. Is there a possibility to create a map with a
>>>> script.
>>>> If "yes". How can I do this.
>>>> Thanks for you help.
>>>> Greetings
>>>> Maik
