[GRASSLIST:9571] Re: script for creating map
Maik Trömel
maik.troemel at maitro.net
Mon Dec 19 04:17:22 EST 2005
When I try to run "d.mon start=PNG" the error doesn't occure. But there
is another error:
after running
d.mon start=PNG
d.mon select=PNG
d.rast geom_summe_s_filt_country
d.vect map=grass_country
d.mon stop=PNG
PNG: GRASS_TRUECOLOR status: FALSE
PNG: collecting to file: map.png,
GRASS_WIDTH=640, GRASS_HEIGHT=480
Graphics driver [PNG] started
100%
Monitor 'PNG' terminated
ERROR - eof from graphics monitor.
Maik
Maik Trömel wrote:
> I tried it out. The problem is, that its not possible to start a display.
> When I run "d.mon start=x0" I get an error:
> ERROR: Graph_Set: can't open Display
> No socket to connect to for monitor <x0>.
> Problem selecting x0. Will try once more
> Any idea what the problem could be?
> Maik
> Michael Barton wrote:
>> Check out the d.out.file script (or it's predecessor, d.out.png) that I
>> wrote and is included with GRASS. This will export whatever is on the
>> current monitor to a png (or other formats if you have gdal). Add
>> d.mon and
>> d.rast and/or d.vect and you can script the creation of a map and its
>> export
>> to png.
>> Michael
>> ______________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution and Social Change
>> Arizona State University
>> Tempe, AZ 85287-2402
>> USA
>> voice: 480-965-6262; fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
>>> From: Maik Trömel <maik.troemel at maitro.net>
>>> Date: Thu, 15 Dec 2005 11:28:48 +0100
>>> To: GRASSLIST <GRASSLIST at baylor.edu>
>>> Subject: [GRASSLIST:9498] script for creating map
>>> Hello Grass-Users,
>>> I want to write a script that creates a map as a png-file. I know
>>> how to
>>> make it by hand. But when I try to script it, it doesn't work because I
>>> can't open a monitor. Is there a possibility to create a map with a
>>> script.
>>> If "yes". How can I do this.
>>> Thanks for you help.
>>> Greetings
>>> Maik
