[GRASSLIST:9570] Re: script for creating map
    Maik Trömel
    maik.troemel at maitro.net
    Mon Dec 19 04:16:38 EST 2005
I tried it out. The problem is, that its not possible to start a display.
When I run "d.mon start=x0" I get an error:
ERROR: Graph_Set: can't open Display
No socket to connect to for monitor <x0>.
Problem selecting x0. Will try once more
Any idea what the problem could be?
Maik
Michael Barton wrote:
> Check out the d.out.file script (or it's predecessor, d.out.png) that I
> wrote and is included with GRASS. This will export whatever is on the
> current monitor to a png (or other formats if you have gdal). Add
> d.mon and
> d.rast and/or d.vect and you can script the creation of a map and its
> export
> to png.
> Michael
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Maik Trömel <maik.troemel at maitro.net>
>> Date: Thu, 15 Dec 2005 11:28:48 +0100
>> To: GRASSLIST <GRASSLIST at baylor.edu>
>> Subject: [GRASSLIST:9498] script for creating map
>> Hello Grass-Users,
>> I want to write a script that creates a map as a png-file. I know how to
>> make it by hand. But when I try to script it, it doesn't work because I
>> can't open a monitor. Is there a possibility to create a map with a
>> script.
>> If "yes". How can I do this.
>> Thanks for you help.
>> Greetings
>> Maik
