[GRASSLIST:9587] Re: script for creating map
Maik Trömel maik.troemel at maitro.net
Tue Dec 20 05:47:11 EST 2005
No, that wasn't the problem.
Is it possible, that it is a Xlib-Problem?
Michael Barton wrote:
> Try running d.mon stop=x0 to clear it out. Then see if d.mon start=x0
> works.
> This can happen if you've had some kind of an improper stopping of
> GRASS or
> monitors.
> Michael
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Maik Trömel <maik.troemel at maitro.net>
>> Date: Mon, 19 Dec 2005 10:00:29 +0100
>> To: Michael Barton <michael.barton at asu.edu>
>> Subject: Re: [GRASSLIST:9552] Re: script for creating map
>> I tried it out. The problem is, that its not possible to start a
>> display.
>> When I run "d.mon start=x0" I get an error:
>> ERROR: Graph_Set: can't open Display
>> No socket to connect to for monitor <x0>.
>> Problem selecting x0. Will try once more
>> Any idea what the problem could be?
>> Maik
>>> Check out the d.out.file script (or it's predecessor, d.out.png) that I
>>> wrote and is included with GRASS. This will export whatever is on the
>>> current monitor to a png (or other formats if you have gdal). Add
>>> d.mon and
>>> d.rast and/or d.vect and you can script the creation of a map and
>>> its export
>>> to png.
>>> Michael
>>> USA
>>>> Date: Thu, 15 Dec 2005 11:28:48 +0100
>>>> To: GRASSLIST <GRASSLIST at baylor.edu>
>>>> Subject: [GRASSLIST:9498] script for creating map
>>>> Hello Grass-Users,
>>>> I want to write a script that creates a map as a png-file. I know
>>>> how to
>>>> make it by hand. But when I try to script it, it doesn't work
>>>> because I
>>>> can't open a monitor. Is there a possibility to create a map with a
>>>> script.
>>>> If "yes". How can I do this.
>>>> Thanks for you help.
>>>> Greetings
>>>> Maik
