[GRASSLIST:9590] Re: v.buffer: area boundary around line? Wanted: howto!
    Wolfgang Qual
    Wolfgang.Qual at gmx.net
    Wed Dec 21 07:19:38 EST 2005
Hi Otto, hi list.
Sorry, I think I was too fast...:
If I *do not specify "type"* in the command for v.buffer (v.buffer
in=ausschnitt out=buff_ausschnitt bufcol=gesamtbr)
I do get a correct result. I can add this vector to my QGIS-Map (Layer
1_polygon) - works.
However: how can I display this in GRASS (d.mon, d.vect)? If I try d.vect,
the area inside the ring is also displayed!
Wolfgang
Buffer is drawn around the feature (line).
> --- Ursprüngliche Nachricht ---
> Von: Otto Dassau <dassau at gdf-hannover.de>
> An: "Wolfgang Qual" <Wolfgang.Qual at gmx.net>
> Kopie: grasslist at baylor.edu
> Betreff: Re: [GRASSLIST:9588] v.buffer: area boundary around line? Wanted:
> howto!
> Datum: Wed, 21 Dec 2005 12:17:50 +0100
> Am Mittwoch, 21. Dezember 2005 11:22 schrieb Wolfgang Qual:
> > Hi List,
> Hi,
> > I tried to create a new area boundary around a line theme. Thought it
> would
> > be easy to do it like this:
> > v.buffer in=ausschnitt out=buff_ausschnitt bufcol=gesamtbr type=boundary
> I also tried with the spearfish location and a CVS snapshot from today and
> got
> similar strange results, where the lines (roads) describe a closed ring.
> v.buffer in=roads out=roadsbuf buffer=20 type=line
>   Otto
> > But GRASS won't create a new theme. After that, I tried to first create
> a
> > line buffer theme (works fine) and then convert it to a area boundary
> theme
> > using v.type. However, the new area boundary theme does not have the
> shape
> > of the line buffer theme.
> > BTW, the line theme looks like this (street network):
> >     |         |       ...but I get s.th.      XXXXXXXXXXXX
> >     |         |       like this:              XXXXXXXXXXXX
> >   --------------                              XXXXXXXXXXXX (area inside)
> > I would greatly appreciate to receive some hints...
> > Best wishes,
> > Wolfgang
> GDF Hannover - Solutions for spatial data analysis and remote sensing
> Office Hannover     -      Mengendamm 16d    -     D - 30177 Hannover
> Internet: www.gdf-hannover.de,               Email: info at gdf-hannover.de
> Phone : ++49.(0)511.39088507,              Fax: ++49.(0)511.39088508
10 GB Mailbox, 100 FreeSMS/Monat http://www.gmx.net/de/go/topmail
+++ GMX - die erste Adresse für Mail, Message, More +++
