[GRASSLIST:9599] Re: Using unixODBC to connect GRASS to MySQL
Hamish
hamish_nospam at yahoo.com
Wed Dec 21 19:17:54 EST 2005
> I believe the MySQL ODBC connector binary is meant for iODBC as
> provided by Apple in the system. GRASS uses UnixODBC.
> GRASS can be made to use iODBC instead - I think the ODBC API is
> standard. I have built GRASS with iODBC instead of UnixODBC, but
> haven't tested it yet. I have an installer that you can try (it
> would be nice to get some testing to see if this works):
> <http://www.kyngchaos.com/macosx/files/grass-6.1cvs.pkg.zip>
Has anyone had luck connecting File Maker Pro on OSX to GRASS via *ODBC?
Hamish
