[GRASSLIST:9606] Hindi support in GRASS 6.1 - was Re: [GRASS5] Fwd: Indic support in GRASS GIS with Indix2
Markus Neteler
neteler at itc.it
Thu Dec 22 05:33:51 EST 2005
Hi again,
an update for support of Indian languages:
- we now have messages files in Hindi available (still to be
translated)
- we can out-of-the-box generate Hindi (or other) scripts
in the GRASS monitor using TTF fonts, see screenshot at
http://grass.itc.it/devel/i18n.php
-> example for Hindi
http://grass.itc.it/images/grass61_hindi_hi.jpg
Note that this is a proof of concept example in Spearfish,
done with:
#extraction of phrase in Hindi:
head -37 locale/po/grassmods_hi.po | tail -1 > /tmp/hindi
echo "599505|4921010|`cat /tmp/hindi | cut -d'"' -f2 `" | v.in.ascii out=hindi
d.rast elevation.dem
v.db.select hindi
d.vect hindi icon=basic/circle
d.font.freetype font=/usr/share/fonts/hi/lohit_hi.ttf
d.vect hindi disp=attr attr=str_1 lsize=40 lcol=blue
Works :-)
Cheers
Markus
On Tue, Dec 20, 2005 at 10:38:44PM +0100, Markus Neteler wrote:
> Hi,
> I have added Hindi support to GRASS by adding two .po files.
> After installing
> kde-i18n-hi-3.4.2-10mdk
> locales-hi-2.3.5-1mdk
> on my Mandriva box, I can even see the characters. With
> d.font.freetype it should be possible to print them on the monitor
> such as for Japanese and Chinese. Screenshots asap...
> I fetched the KDE Hindi file and autotranslated the GRASS
> messages, some hundred fuzzy translations resulted. Since
> my Hindi is a bit rusty, I would leave the verification to
> native speakers.
> You can grab the wto hindi files from here
> -> Download current .po files from CVS
> -> grasslibs_hi.po
> -> grassmods_hi.po
> Please send updates to these files regularly, in order to
> stay in sync.
> If needed, I can add other languages are well.
> Cheers
> Markus
> On Mon, Dec 19, 2005 at 07:43:53AM +0100, Swapnil Hajare wrote:
> > hi,
> > greetings.
> > not sure if the new GTK gui will solve our problem. Does the new GUI means
> > GRASS monitors will use pango for rendering? I guess they will use the same
> > monitor. And by the time they come up with new GUI, should we wait for them
> > to finish and then start our localised GIS work ? My feeling is this should
> > be seen as a patch for indic support (similar to d.text.freetype used for
> > CJK). correct me if I am wrong.
> > I am also not sure how many indic scripts are supported well by Pango/QT
> > and what is the quality of rendering for all these scripts. If this solution
> > can provide a better rendering solution, it has every right to be accepted
> > as a good alternative to Pango/Qt.
> > bye
> > On 12/19/05, Sajith VK <sajithvk at gmail.com> wrote:
> > > Hello all,
> > > Sorry for a much belated response.
> > > Indian Language support for GRASS (For GUI and
> > > in the map lables) will be highly benificiary.
> > > A discussion on a better GUI for GRASS is already
> > > going on. I think it may end up with using GTK or
> > > QT as toolkit. Both GTK and QT has indian language
> > > support.
> > > So this work may become irrelevent, according to the
> > > future plans of the GUI team. So we may need to switch
> > > to pango/Qt
> > > On 12/8/05, Swapnil Hajare <dreamil at gmail.com> wrote:
> > > > HI all,
> > > > my first post. I hope I am posting this is right list.
> > > > this is for your comments. If it sounds ok, can some 2-3MB code of
> > > Indix2
> > > > (indic Shaping Engine) be included in grass code to claim something like
> > > > "GRASS GIS supports 11 Indian Scripts" ?
> > > Change the rules, or the rules will change you
> > > ---------Kumaranasan
> > Swapnil Hajare
> Markus Neteler <neteler itc it> http://mpa.itc.it
> ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18 - 38050 Povo (Trento), Italy
