[GRASSLIST:9627] Re: water resource management with GRASS & RDBMS
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Fri Dec 23 10:02:19 EST 2005
Hello, I've just used some functions of the ArcHydroTools....
Then I just developed a DB structure for online-realtime stationa and a
Rainfall-runoff Distributed Model within GRASS (embedded)....
I think that your idea is really nice and helpfull.
I also think that it could be ported in the OpenSource by using GRASS
data structure!!!
I also believe that I could adjust my model to get starting data and
pre-processing from this new data structure,
in order to build an hydrologic GRASS application structure...
I used the perfix h.modulename for my new developed command.
This could be an idea....
currently my model name is HydroFOSS... so OpenHydro I think is free :-)
Let me know your impression.
Have a nice holyday.
Massimiliano
M S wrote:
>As some of you may or may not know. that OTHER software company is trying
>to establish their Geodatabase data model as a "GIS standard" (at least this
>is the trend in the US from what I'm seeing). I havent been impressed or
>enthused about it at all. This second generation, "windows only" software
>(arcmap) by that other company has had many, many shortcomings, failure to
>function in a production environment, and bugs that hardly justify the price
>tag.
>In their attempt to weave the Geodatabase into the fabric of government
>agencies and large corporations, which has the trickle down effect on
>consultants who work for them (Water management agencies in this specific
>application), they have come out with this "ArcHydro" concept. RFPs are
>coming out asking for "ArcHydro".
>The book for arcHydro states right up front, (although you have to really
>read between the lines), it is still a pre/post processor for real water
>model simulation software to do what they do best. However, it is obviously
>biased from that other company's geodatabase approach. In reading it thus
>far, i really dont see why this cannot be done with GRASS and a RDBMS.
>Has anyone implemented and used arcHydro? If so, what is your thoughts on a
>GRASS/RDBMS approach?
>Would anyone find a corresponding open source solution document, which
>unless conflicting with an existing name already, I will call "OpenHydro",
>useful as an open source solution to what the proprietary company is
>promoting in their latest round of propaganda?
>I am forced to learn this ArcHydro procedure/framework to do a project our
>company won, which called specifically for the implementation of ArcHydro.
>However, through my readings and implementation, I plan on making the same
>concept available through open source tools, specifically with the use of
>GRASS and a RDBMS.
>Basically I'm looking to find 1) anyone who has used arcHydro and 2) if
>there is interest in generating an "OpenHydro" alternative using GRASS.
>Surely all the open source developers and users are on the "nice" list of
>Santa!
>Wishing Happy Holidays around the world!
Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 18
Fax +41 (0)58 666 62 09
