[GRASSLIST:9629] Re: water resource management with GRASS & RDBMS
    M S
    mseibel at gmail.com
    Fri Dec 23 10:24:16 EST 2005
excellent!  I have much more reading to do, and as i continue down the road
I will proabalby be seeking help from people like your self.
once I gain more experience with archydro (i'm a vetern of arc/info vector
and raster data modeling, and they hydro functions within the A/I GRID
module) I will be able to apply these concepts to the GRASS modules.
On 12/23/05, Massimiliano Cannata <massimiliano.cannata at supsi.ch> wrote:
> Hello, I've just used some functions of the ArcHydroTools....
> Then I just developed a DB structure for online-realtime stationa and a
> Rainfall-runoff Distributed Model within GRASS (embedded)....
> I think that your idea is really nice and helpfull.
> I also think that it could be ported in the OpenSource by using GRASS
> data structure!!!
> I also believe that I could adjust my model to get starting data and
> pre-processing from this new data structure,
> in order to build an hydrologic GRASS application structure...
> I used the perfix h.modulename for my new developed command.
> This could be an idea....
> currently my model name is HydroFOSS... so OpenHydro I think is free :-)
> Let me know your impression.
> Have a nice holyday.
> Massimiliano
> M S wrote:
> >As some of you may or may not know.  that OTHER software company is
> trying
> >to establish their Geodatabase data model as a "GIS standard" (at least
> this
> >is the trend in the US from what I'm seeing).  I havent been impressed or
> >enthused about it at all.  This second generation, "windows only"
> software
> >(arcmap) by that other company has had many, many shortcomings, failure
> to
> >function in a production environment, and bugs that hardly justify the
> price
> >tag.
> >In their attempt to weave the Geodatabase into the fabric of government
> >agencies and large corporations, which has the trickle down effect on
> >consultants who work for them (Water management agencies in this specific
> >application), they have come out with this "ArcHydro" concept.  RFPs are
> >coming out asking for "ArcHydro".
> >The book for arcHydro states right up front, (although you have to really
> >read between the lines), it is still a pre/post processor for real water
> >model simulation software to do what they do best.  However, it is
> obviously
> >biased from that other company's geodatabase approach.  In reading it
> thus
> >far, i really dont see why this cannot be done with GRASS and a RDBMS.
> >Has anyone implemented and used arcHydro?  If so, what is your thoughts
> on a
> >GRASS/RDBMS approach?
> >Would anyone find a corresponding open source solution document, which
> >unless conflicting with an existing name already, I will call
> "OpenHydro",
> >useful as an open source solution to what the proprietary company is
> >promoting in their latest round of propaganda?
> >I am forced to learn this ArcHydro procedure/framework to do a project
> our
> >company won, which called specifically for the implementation of
> ArcHydro.
> >However, through my readings and implementation, I plan on making the
> same
> >concept available through open source tools, specifically with the use of
> >GRASS and a RDBMS.
> >Basically I'm looking to find 1) anyone who has used arcHydro and 2) if
> >there is interest in generating an "OpenHydro" alternative using GRASS.
> >Surely all the open source developers and users are on the "nice" list of
> >Santa!
> >Wishing Happy Holidays around the world!
> Eng. Massimiliano Cannata
> Scuola Universitaria Professionale della Svizzera Italiana
> Istituto Scienze della Terra
> Via Trevano, c.p. 72
> CH-6952 Canobbio-Lugano
> Tel: +41 (0)58 666 62 18
> Fax +41 (0)58 666 62 09
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051223/f9f7d389/attachment.html
