[GRASSLIST:9647] Re: real color landsat images
Maciek Sieczka werchowyna at epf.pl
Mon Dec 26 09:57:28 EST 2005
Wolfgang,
If you use OpenEV try Mario Beauchamp's fusion tool snake at
http://pages.infinit.net/starged/openev/index.htm.
It is easy to install (just copy the script to the tools dir) and
supports Landsat imagery perfect, as well as Quickbird (haven't tried).
It's great that Mario shared this piece of his fine work.
Maciek
On nie, 2005-12-25 at 13:19 +0000, Glynn Clements wrote:
> Wolfgang Zillig wrote:
> > I know how to combine the band (_10, _20, _30) to real color images
> > with r.rgb. But then the resolution is limited to 30m. Is there a way
> > to get them in higher resolution with the pan band (_80)? When I use
> > i.fusion.brovey I get always false color pictures. Any idea?
> One option to try is rgb.hsv.sh, replace V with the panchromatic map,
> then hsv.rgb.sh.
> Hmm; those scripts don't appear to be included in 6.1, but they are in
> 5.3.
> Better still, go through YUV instead of HSV; the calculations are
> simpler. The coefficients can be found at:
> 	http://en.wikipedia.org/wiki/YUV
> The equations can be implemented in r.mapcalc easily enough.
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
