[GRASSLIST:9657] Re: Import Gridded Population of the World
Markus Neteler
neteler at itc.it
Wed Dec 28 05:23:16 EST 2005
Karl,
did you zoom to the map?
g.region rast=gpw -p
Then you may check the statistics (probably just the color
table is non-representative):
r.univar gpw
If everything is still zero, please let us know.
Markus
On Tue, Dec 27, 2005 at 05:06:55PM +0100, Karl Broich wrote:
> Hello,
> I tried to import the raster files of gpw (*bil etc.). The import via
> r.in.gdal runs without errors but the resulting raster is empty (just zero
> values).
> Is this a known problem ?
> Thanks in advance
> Karl Broich
> Dr.-Ing. Karl BROICH Tel: +49 / (0) 89 / 6004 2478
> Universität der Bundeswehr München Fax: +49 / (0) 89 / 6004 3858
> Institut für Wasserwesen
> Werner-Heisenberg-Weg 39
> D 85577 Neubiberg
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
