[GRASSLIST:5595] RE: how run out of grass
Miguel A. Altamirano del C
mgaac at yahoo.com
Tue Feb 1 14:21:16 EST 2005
to include the library path was good but now i get the
following error:
ERROR: Cannot get GIS_LOCK enviroment variable value
Problem selecting x1. Will try once more
How i can solve this problem, if i'm working in suse
9.0 with grass6.0
Thanks for any help
--- Eric Pante <ericpante at hotmail.com> escribió:
> hello miguel,
> I actually have to do the same thing with grass... I
> took your script and
> ran it on my machine; I don't know waht ia the error
> message you received,
> but mine said that the library libgrass_gis.so could
> not be found.
> I fixed the problem by adding the following lines
> after the ETC= and PATH=
> .... lines :
> LD_LIBRARY_PATH=$GISBASE/lib:$LD_LIBRARY_PATH
> DYLD_LIBRARY_PATH=$GISBASE/lib:$DYLD_LIBRARY_PATH
> that way grass finds the libraries. next you need to
> add LD_LIBRARY and
> DYLD_LIBRARY to the export line, as:
> export GISBASE GISDBASE ETC PATH GISRC
> LD_LIBRARY_PATH DYLD_LIBRARY_PATH
> this made the script to work on my machine,
> hope this help,
> eric pante
> <html><div><DIV align=left>
> <DIV align=left>Eric Pante</DIV>
> <DIV align=left><FONT size=2>Graduate Student in
> Marine Biology</FONT></DIV>
> <DIV align=left><FONT size=2>Grice Marine
> Laboratory</FONT></DIV>
> <DIV align=left><FONT size=2>205 Fort Johnson,
> Charleston SC
> 29412</FONT></DIV>
> <DIV> </DIV>
> <DIV align=center><EM>On ne force pas la curiosité,
> on l'éveille.</EM></DIV>
> <DIV align=center>Daniel Pennac</DIV>
> <DIV>
> <TABLE width="100%" border=0>
> <TBODY>
> <TR>
> <TD vAlign=top align=left>
> <P align=center><FONT face="Lucida Handwriting,
> Cursive"
> size=2><STRONG></P></STRONG></FONT>
> <P
align=center> </P></TD></TR></TBODY></TABLE></DIV>
> <DIV>
> <TBODY>
> <TR>
> <TD vAlign=top
align=right></TD></TR></TBODY></TABLE></DIV></DIV></div></html>
> >From: "Miguel A. Altamirano del C"
> <mgaac at yahoo.com>
> >To: grasslist at baylor.edu
> >Subject: [GRASSLIST:5552] how run out of grass
> >Date: Fri, 28 Jan 2005 11:59:44 -0600 (CST)
> >I have the sh file "batch-miguel.sh"
> and one file with
> >grass's command "z-kk", when run it
> with:
> >"sh batch-miguel.sh grasspru PERMANENT
> -file z-kk" in
> >the
> >grass environment, it run but when i try to run
> out of
> >the grass environment don't run. I wish to run
> my
> >grass command in background form.
> >Anyone can tell me how can i to run my scripts
> in this
> >form, without be in grass environment.
> >LCA Miguel A. Altamirano del C.
> >"Los Mexicanos llevamos la fiesta en la
> garganta"
> >Tel. 01(232)32 45208
> >La belleza de la meteorología radica en saber
> >pronosticarla y no simplemente en estudiarla
> > (Miguel A. Altamirano 28-5-00)
>_________________________________________________________
> >Do You Yahoo!?
> >Información de Estados Unidos y América Latina,
> en Yahoo! Noticias.
> >Visítanos en http://noticias.espanol.yahoo.com
> ><< batch-miguel.sh >>
> ><< z-kk >>
"Los Mexicanos llevamos la fiesta en la garganta"
Do You Yahoo!?
Información de Estados Unidos y América Latina, en Yahoo! Noticias.
