[GRASSLIST:5601] Re: FW: grass-6.0.cvs_src_snapshot_2005_01_29 compilation, programm error?
Wed Feb 2 01:13:40 EST 2005
[cygwin compiled from source]
 -- why not try the 6.0 binary?
   http://geni.ath.cx/grass.html
> The "./configure" stopts again because of missing FFTW.
> ./configure --without-fftw
You only need FFTW if you want to use the i.fft or i.ifft modules.
> Unfortunately, whes I start startx & window and type grass60, Grass
> does not start and give the following messages:
> $grass60
> Searching for web browser, but neither konqueror, nor mozilla, opera,
> netscape found.
> Cleaning up temporary files.
> /usr/local/grass-6.0.cvs/etc/clean_temp: not found
> Starting GRASS...
> Error in startup script: couldn't read file
> "/usr/local/grass-6.0.cvs/etc/gis_set.tcl": no such file or directory
> Error in Tcl/Tk startup. If necessary, please report this error to the
> GRASS developers.
> Switchinh to text mode now.
> Hit return to continue...
> /usr/local/grass-6.0.cvs/etc/set_data: not found
> Wwat could be wrong?
looks like none of the files made it into /usr/local/grass-6.0.cvs/etc/
what is in that directory?
did error.log report anything?
Hamish
