[GRASSLIST:5602] Re: EPSG codes at startup
Paolo Cavallini cavallini at faunalia.it
Wed Feb 2 01:41:00 EST 2005
Hi Michael.
I know of the EPSG list; it has been a relevant improvement. Its usage,
however, can be improved. Currently, one has to look up the codes, choose the
right one, remember it, and write it back to the appropriate field (on the
previous window). This looks rather primitive, and I suspect (no TclTk
knowlwdge, so I may be wrong) it should be easy to have a more standard
behaviour (choose an item from a list, and the chosen value goes into the
form).
The main problem I see is that the list is very long, and probably difficult
to browse. So the new system used by qgis (as suggested by Markus) looks
promising.
As for the help, please forgive me (I didn't notice it). I'll test it with
students in the next weeks and I'll suggest improvements if necessary.
All the best.
pc
At 05:25, mercoledì 2 febbraio 2005, Michael Barton has probably written:
> Paolo,
> Because I don't use EPSG, I hadn't looked at the EPSG startup and so
> replied in ignorance. It turns out that there IS a list of EPSG codes that
> you can browse and select from...and it is VERY long. Still, it is very
> much what you were wishing for. You also have the option of making a new
> EPSG location that is not on the list it seems. I am copying the list to
> make sure that others know about this alternate (and possibly easier) way
> of setting up a location.
> Also, I want to note that the startup help--called by the appropriately
> named "help" button when GRASS starts up ;-) --is a pretty nice piece of
> information for new users. Furthermore, Markus set it up in what appears to
> be an extensible help system. So if anyone wants to build on this to make
> additional startup help topics, it should be doable.
Paolo Cavallini
cavallini at faunalia.it   www.faunalia.it   www.faunalia.com
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
