[GRASSLIST:5606] Re: TOPMODEL
wouter buytaert
wouter.buytaert at tiscali.be
Wed Feb 2 06:47:44 EST 2005
Hello Aude,
the r.topmodel module takes the same input files as the original
topmodel developed by prof. Beven. You can find his version at:
http://www.es.lancs.ac.uk/hfdg/topmodel.html
However, the GRASS module is of limited use as it doesn't have the monte
carlo sensitivity analysis built in. It might be better to export the
topographic index map for GRASS to ascii and use this map as input in
the original program, if you've got windows machine available, of
course...
Wouter
On Tue, 2005-01-25 at 10:14 +0100, aude.vincent at no-log.org wrote:
> Hi,
> I'm trying to use r.topmodel, but can't find any details on the structure
> of the input files, especially the parameters one.
> Does anyone have experience with this?
> thanks,
> Aude
wouter buytaert <wouter.buytaert at tiscali.be>
