[GRASSLIST:5649] vector export to GMT->simplify vectors
    Dylan Beaudette
    dylan at iici.no-ip.org
    Fri Feb  4 21:48:57 EST 2005
Greetings!
I have a simple vector that is composed of 2 areas:
http://169.237.35.250/~dylan/gmt/ptuff.png
v.info reports:
|   Number of points:       0               Number of areas:      2
|   Number of lines:        0               Number of islands:    2
|   Number of boundaries:   18              Number of faces:      0
|   Number of centroids:    2               Number of kernels:    0
I am interested in exporting the boundaries that represent the 2 areas in this
vector with v.out.asci, for useage in GMT...
However, when i run v.out.ascii format=standard ....
I am left with an ascii file that describes all 18 boundaries that exist in
the vector ptuff.... resulting in a file that is of little use in GMT... see
the result (blue polygon is the problem one...):
http://169.237.35.250/~dylan/gmt/geology.png
Where do all 18 boundaries come from? How can I only export the ones
associated with the 2 areas?
Any ideas?
PS I am using GRASS6
Thanks,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
