[GRASSLIST:5650] Re: vector export to GMT->simplify vectors
Dylan Beaudette
dylan at iici.no-ip.org
Fri Feb 4 21:59:05 EST 2005
Sorry about replying to my original post... but I have a bit more information
to refine my problem:
the 18 "boundaries" are actually 18 line segments that make up the 2 real
boundaries.
Thus, the question would then be:
is it possible to convert a set of line segments into a single line...?
thanks!
On Friday 04 February 2005 06:48 pm, Dylan Beaudette wrote:
> Greetings!
> I have a simple vector that is composed of 2 areas:
> http://169.237.35.250/~dylan/gmt/ptuff.png
> v.info reports:
> | Number of points: 0 Number of areas: 2
> | Number of lines: 0 Number of islands: 2
> | Number of boundaries: 18 Number of faces: 0
> | Number of centroids: 2 Number of kernels: 0
> I am interested in exporting the boundaries that represent the 2 areas in
> this vector with v.out.asci, for useage in GMT...
> However, when i run v.out.ascii format=standard ....
> I am left with an ascii file that describes all 18 boundaries that exist in
> the vector ptuff.... resulting in a file that is of little use in GMT...
> see the result (blue polygon is the problem one...):
> http://169.237.35.250/~dylan/gmt/geology.png
> Where do all 18 boundaries come from? How can I only export the ones
> associated with the 2 areas?
> Any ideas?
> PS I am using GRASS6
> Thanks,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
