[GRASSLIST:5679] Re: AW: Tiff import
    Grit Schuster
    grit.schuster at geographie.uni-freiburg.de
    Tue Feb  8 14:35:17 EST 2005
r.composite is just working for three layers.
I'm trying to put together 6 or so different raster layers,
e.g.
1. layer includes waterbodies,
2. layer: contour lines
3. layer: signatures
4. layer: vegetation
and so on ...
What about using r.mapcalc for that kind of problem?
Grit
On Tue, 8 Feb 2005 17:41:10 +0100
 "Marco Lechner" <marco.lechner at geographie.uni-freiburg.de>
wrote:
> try r.composite
> Marco
> -----Ursprüngliche Nachricht-----
> Von: owner-GRASSLIST at baylor.edu
> [mailto:owner-GRASSLIST at baylor.edu]Im
> Auftrag von Grit Schuster
> Gesendet: Dienstag, 8. Februar 2005 16:30
> An: grasslist at baylor.edu
> Betreff: [GRASSLIST:5675] Tiff import
> Hello,
> I imported different TIFF-layers of one
> topographic map, using r.gdal.
> Now I want to put the single layers in one map.
> How can I do this quickly?
> Thanks for any clues!
> Grit
