[GRASSLIST:5681] Re: AW: Tiff import
    Ian MacMillan
    ian_macmillan at umail.ucsb.edu
    Tue Feb  8 14:47:19 EST 2005
Grit,
I am not sure if this is what you want, but this might work.  If all of
your data are from TIFFs, then you will first need to make sure that
your white space is null.  Use r.null and convert zero values to null.
Once you have done that for all layers, you can patch them all together
with r.patch.  See the help pages for how each command works
G'luck
-Ian
On Feb 8, 2005, at 11:35 AM, Grit Schuster wrote:
> r.composite is just working for three layers.
> I'm trying to put together 6 or so different raster layers,
> e.g.
> 1. layer includes waterbodies,
> 2. layer: contour lines
> 3. layer: signatures
> 4. layer: vegetation
> and so on ...
> What about using r.mapcalc for that kind of problem?
> Grit
> On Tue, 8 Feb 2005 17:41:10 +0100
>  "Marco Lechner" <marco.lechner at geographie.uni-freiburg.de>
> wrote:
>> try r.composite
>> Marco
>> -----Ursprüngliche Nachricht-----
>> Von: owner-GRASSLIST at baylor.edu
>> [mailto:owner-GRASSLIST at baylor.edu]Im
>> Auftrag von Grit Schuster
>> Gesendet: Dienstag, 8. Februar 2005 16:30
>> An: grasslist at baylor.edu
>> Betreff: [GRASSLIST:5675] Tiff import
>> Hello,
>> I imported different TIFF-layers of one
>> topographic map, using r.gdal.
>> Now I want to put the single layers in one map.
>> How can I do this quickly?
>> Thanks for any clues!
>> Grit
