[GRASSLIST:5683] how to reduce decimal points
Miguel A. Altamirano del C mgaac at yahoo.com
Tue Feb 8 16:09:50 EST 2005
Hi grass community:
I've a "text file" with Lat Lon Var1... VarN (float
type) and i import it with "v.in.ascii -z ...
out=test", when i display my data with "d.vect test
display=shape,zcoor" all it's ok, my question is:
zcoor has Var1, how can i change the variable type in
zcoor (Var2, or Var3 or VarN) or maybe i must to
import "text file" for each variable???
When i display "d.vect test display=shape,attr
attrcol=ANYvar" appears in the terminal values, per
example, as 275.000000 or 315.450000, well, the help
that i ask is how do i do to put only 2 or 3 places
after the decimal point???
LCA Miguel A. Altamirano del C.
"Los Mexicanos llevamos la fiesta en la garganta"
Tel. 01(232)32 45208
La belleza de la meteorología radica en saber
pronosticarla y no simplemente en estudiarla
      (Miguel A. Altamirano 28-5-00)
_________________________________________________________
Do You Yahoo!?
Información de Estados Unidos y América Latina, en Yahoo! Noticias.
Visítanos en http://noticias.espanol.yahoo.com
