[GRASSLIST:5686] Grass 6.0 and PG Database - tables not being deleted when vectors g.removed
Craig Aumann caumann at ualberta.ca
Tue Feb 8 19:24:15 EST 2005
I recently upgraded from an older version of Grass57 to the new Grass
6.  I can't figure out why the posgressql tables aren't being removed
when I delete a vector.
Here's my setup:
GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > db.connect -p
driver:pg
database:dbname=L11SAGD,user=caumann
schema:(null)
group:(null)
GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > v.db.connect -p fma
Vector map <fma> is connected by:
layer <1> table <fma> in database <dbname=L11SAGD,user=caumann> through
driver <pg> with key <cat>
g.copy vect=fma,fmacopy
COPY [fma at caumann] to current mapset as [fmacopy]
WARNING: 'user' in database definition is not supported, use db.login
> v.db.connect -p fmacopy
Vector map <fmacopy> is connected by:
layer <1> table <fmacopy> in database <dbname=L11SAGD,user=caumann>
through driver <pg> with key <cat>
> GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > g.remove vect=fmacopy
REMOVE [fmacopy]
WARNING: Table 'fmacopy' linked to vector did not exist.
WHAT??? The table IS in the database.
GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > db.tables -p
public.fma
public.fmacopy
fmacopy is still in the database....  What is going on???
Cheers!
Craig
