[GRASSLIST:5733] Re: Grass 6.0 and PG Database - tables not being
 deleted when vectors	g.removed
    Radim Blazek
    blazek at itc.it
    Fri Feb 11 09:47:53 EST 2005
g.remove (db_table_exists) was using fully qualified names (table.schema
->public.fmacopy) so it could not find fmacopy.
I have fixed that so that if the input table name is fully qualified,
db_table_exists checks full name otherwise only table.
I am not sure if it is the best solution, unfortunately we don't have
enough experience with schemas. The table with the same name can be in
other schema.
I think that it is better to use db.connect schema=, even if you use
only public.
Radim
Craig Aumann wrote:
> I recently upgraded from an older version of Grass57 to the new Grass
> 6.  I can't figure out why the posgressql tables aren't being removed
> when I delete a vector.
> Here's my setup:
> GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > db.connect -p
> driver:pg
> database:dbname=L11SAGD,user=caumann
> schema:(null)
> group:(null)
> GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > v.db.connect -p fma
> Vector map <fma> is connected by:
> layer <1> table <fma> in database <dbname=L11SAGD,user=caumann> through
> driver <pg> with key <cat>
> g.copy vect=fma,fmacopy
> COPY [fma at caumann] to current mapset as [fmacopy]
> WARNING: 'user' in database definition is not supported, use db.login
>>v.db.connect -p fmacopy
> Vector map <fmacopy> is connected by:
> layer <1> table <fmacopy> in database <dbname=L11SAGD,user=caumann>
> through driver <pg> with key <cat>
>>GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > g.remove vect=fmacopy
> REMOVE [fmacopy]
> WARNING: Table 'fmacopy' linked to vector did not exist.
> WHAT??? The table IS in the database.
> GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > db.tables -p
> public.fma
> public.fmacopy
> fmacopy is still in the database....  What is going on???
> Cheers!
> Craig
