[GRASSLIST:5735] Re: Grass 6.0 and PG Database - tables not being deleted when vectors g.removed
Kirk R. Wythers kwythers at umn.edu
Fri Feb 11 10:48:26 EST 2005
I was looking at this issue this morning and thought that db.droptable
might work. However, db.droptable does not seem to be in my build of
grass6 (cvs a few days ago). Was db.droptable dropped?
Kirk
On Feb 11, 2005, at 8:47 AM, Radim Blazek wrote:
> g.remove (db_table_exists) was using fully qualified names
> (table.schema ->public.fmacopy) so it could not find fmacopy.
> I have fixed that so that if the input table name is fully qualified,
> db_table_exists checks full name otherwise only table.
> I am not sure if it is the best solution, unfortunately we don't have
> enough experience with schemas. The table with the same name can be in
> other schema.
> I think that it is better to use db.connect schema=, even if you use
> only public.
> Radim
> Craig Aumann wrote:
>> I recently upgraded from an older version of Grass57 to the new Grass
>> 6.  I can't figure out why the posgressql tables aren't being removed
>> when I delete a vector.
>> Here's my setup:
>> GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > db.connect -p
>> driver:pg
>> database:dbname=L11SAGD,user=caumann
>> schema:(null)
>> group:(null)
>> GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > v.db.connect -p fma
>> Vector map <fma> is connected by:
>> layer <1> table <fma> in database <dbname=L11SAGD,user=caumann>
>> through
>> driver <pg> with key <cat>
>> g.copy vect=fma,fmacopy
>> COPY [fma at caumann] to current mapset as [fmacopy]
>> WARNING: 'user' in database definition is not supported, use db.login
>>> v.db.connect -p fmacopy
>> Vector map <fmacopy> is connected by:
>> layer <1> table <fmacopy> in database <dbname=L11SAGD,user=caumann>
>> through driver <pg> with key <cat>
>>> GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > g.remove vect=fmacopy
>> REMOVE [fmacopy]
>> WARNING: Table 'fmacopy' linked to vector did not exist.
>> WHAT??? The table IS in the database.
>> GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > db.tables -p
>> public.fma
>> public.fmacopy
>> fmacopy is still in the database....  What is going on???
>> Cheers!
>> Craig
