[GRASSLIST:5736] Re: Grass 6.0 and PG Database - tables not being
deleted when vectors g.removed
Radim Blazek
blazek at itc.it
Fri Feb 11 11:02:33 EST 2005
Kirk R. Wythers wrote:
> I was looking at this issue this morning and thought that db.droptable
> might work. However, db.droptable does not seem to be in my build of
> grass6 (cvs a few days ago). Was db.droptable dropped?
Yes, it was removed from Makefile because db_drop_table was not
implemented in drivers.
echo "drop table fmacopy" | db.execute
Radim
> Kirk
> On Feb 11, 2005, at 8:47 AM, Radim Blazek wrote:
>> g.remove (db_table_exists) was using fully qualified names
>> (table.schema ->public.fmacopy) so it could not find fmacopy.
>> I have fixed that so that if the input table name is fully qualified,
>> db_table_exists checks full name otherwise only table.
>> I am not sure if it is the best solution, unfortunately we don't have
>> enough experience with schemas. The table with the same name can be in
>> other schema.
>> I think that it is better to use db.connect schema=, even if you use
>> only public.
>> Radim
>> Craig Aumann wrote:
>>> I recently upgraded from an older version of Grass57 to the new Grass
>>> 6. I can't figure out why the posgressql tables aren't being removed
>>> when I delete a vector.
>>> Here's my setup:
>>> GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > db.connect -p
>>> driver:pg
>>> database:dbname=L11SAGD,user=caumann
>>> schema:(null)
>>> group:(null)
>>> GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > v.db.connect -p fma
>>> Vector map <fma> is connected by:
>>> layer <1> table <fma> in database <dbname=L11SAGD,user=caumann> through
>>> driver <pg> with key <cat>
>>> g.copy vect=fma,fmacopy
>>> COPY [fma at caumann] to current mapset as [fmacopy]
>>> WARNING: 'user' in database definition is not supported, use db.login
>>>> v.db.connect -p fmacopy
>>> Vector map <fmacopy> is connected by:
>>> layer <1> table <fmacopy> in database <dbname=L11SAGD,user=caumann>
>>> through driver <pg> with key <cat>
>>>> GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > g.remove vect=fmacopy
>>> REMOVE [fmacopy]
>>> WARNING: Table 'fmacopy' linked to vector did not exist.
>>> WHAT??? The table IS in the database.
>>> GRASS 6.0.cvs:~/sagdalpac/AREAS/L11SAGD > db.tables -p
>>> public.fma
>>> public.fmacopy
>>> fmacopy is still in the database.... What is going on???
>>> Cheers!
>>> Craig
