[GRASSLIST:5698] Re: Importing Data.
    H S Rai
    hardeep at eml.cc
    Wed Feb  9 12:37:33 EST 2005
Yesterday at 12:34pm +1300 Hamish wrote:
>   > 1. Save the ARC-INFO files as SHAPE files
>   (ie for vector data; for raster data you can load an Arc binary grid
>   into GRASS with r.in.gdal)
Thank you Ravi and Hamish for your help.
H.S.Rai    http://www.grex.org/~hsrai | Registered Linux User # 223684
http://counter.li.org/cgi-bin/runscript/display-person.cgi?user=223684
####[ GNU/Linux One Stanza Tip (LOST) ]#######################
Sub : Single user mode booting under grub            LOST #266
To enter single user mode under grub, press "e" [edit] at the
grub boot menu and edit the boot parameters  "kernel /vmlinuz
root=/dev/hdN single" (where N = your root partition)... Then
reboot using "b" [boot]... Easy ?
####[ragu (at) vsnl.com]######################################
