[GRASSLIST:5704] projection conversion
    Helmut Kudrnovsky
    hellik at web.de
    Thu Feb 10 01:29:48 EST 2005
hi GRASS-friends,
i´ve got a ascii-point-file from bird and amphibian watching measured in the Austrian Gauss-Krüger grid system (zone M31) based on the transverse mercator projection and the bessel ellipsoid:
43504.88195 326077.81792
44075.95816 324073.80644
43720.53742 324984.62938
i would need the points in a latitude-longitude format (geographic coordinate system). but i´m not sure about the procedure to get it:
1 - create a new location with epsg-code  31285 (MGI / M31)
2  import the ascii-file with v.in.ascii
3  create a new location with latitude-longitudinal coordinate system, the hermannskogel datum and the Datum Transformation Parameter 1 for Austria
4  projection conversion with v.proj
5  export with v.out.ogr or v.out.ascii
is there may be a shorter way to do this?
with greetings from the snowy tyrol
helli
__________________________________________________________
Mit WEB.DE FreePhone mit hoechster Qualitaet ab 0 Ct./Min.
weltweit telefonieren! http://freephone.web.de/?mc=021201
