[GRASSLIST:5740] Re: region/location/projection problem
    Ian MacMillan
    ian_macmillan at umail.ucsb.edu
    Fri Feb 11 15:12:13 EST 2005
Lizhong, so it sounds like there are a few things you need to know
about GIS (I hope I am not being presumptuos).  The first thing is that
all information is geocoded, or it isn't (not very profound).  Suppose
a raster file has geocoding information in it, if you import it into a
location that has the same projection parameters (i.e. latlong, wgs84),
then the map will show up in the part of the world it is supposed to.
Every location has a unique projection.  If your raster does not have
projection data associated with it (like all jpegs, gifs, etc.), then
you need to import it into an XY location (this location has no
projection).  When importing into XY locations, all rasters come in
with the top right corner at the origin (just because).  The reason it
came in as -915-0 etc. is because your jpeg is a 915x587 pixel image.
Generally once you have a map in the XY location, you will want to
project it to another location that has projection parameters that
match some kind of real world map.  This is why you would use a GIS.
If you just want to edit a raster without a projection, then GRASS is
probably the wrong application.  I hope this is helpful.  If you have
more specific questions about how to fit your jpeg into another
location, there is info in the archives, or write back.
G'luck
-Ian
On Feb 11, 2005, at 7:34 AM, ljin at hunter.cuny.edu wrote:
> Hi,
> I am a new starter for GRASS. I create a new location and its mapset
> in a new
> directory (database). The region was set as 0-10000 (W-E) and 0-10000
> (S-N)
> when I did the creation. But after a map was imported (.jpg file,
> downloaded
> from website), this imported map's region was -915-0 (W-E) and -587-0
> (S-N), in
> the -/- area (the third quadrant of Cartesian coordinate system?). I
> tried
> serveral times with similar downloaded maps, the imported maps always
> falled in
> this area. How to sovle this problem? How to let the map "sit" in a
> region as I
> want? Thanks for help.
> Lizhong Jin
