[GRASSLIST:5742] Re: region/location/projection problem
    Hamish
    hamish_nospam at yahoo.com
    Fri Feb 11 23:53:12 EST 2005
hello nyc..
> When importing into XY locations, all rasters come in
> with the top right corner at the origin (just because).  The reason it
> came in as -915-0 etc. is because your jpeg is a 915x587 pixel image.
It uses the top-right of the image as the origin because r.in.gdal sets
it that way if the image doesn't contain geocoding. Older modules in
GRASS 5.0 used the bottom left as the origin (eg r.in.tiff and r.in.png).
You can reset it with r.region if you want.
Hamish
