[GRASSLIST:5755] errors on 5.4.0 build
Kent Hodges hodgesk at eastlink.ca
Sun Feb 13 23:51:51 EST 2005
Hello,
I am trying to build grass 5.4.0 on Mandrake 10.0 CE. I have one problem left.
I  receive the following errors from build:
Compilation error in module: src/libes/dbmi/lib
Compilation error in module: src/libes/dbmi/clients
Compilation error in module: src/display/d.db
Compilation error in module: src/display/d.what.db
Compilation error in module: src/display/d.what.vect
Compilation error in module: src/mapdev/v.db.reclass
Compilation error in module: src/mapdev/v.out.shape
Compilation error in module: src/mapdev/v.to.db
Compilation error in module: src.contrib/SDTS
Compilation error in module: src/libes/dbmi/drivers/odbc
There are no problems in compile. If I check make.log these errors are all
caused by an undefined reference to db_malloc. Can anyone help me figure out
which library I am missing or have the wrong version of installed.
Kent Hodges
