[GRASSLIST:5756] Re: errors on 5.4.0 build
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Feb 14 04:18:47 EST 2005
On Mon, 14 Feb 2005, Kent Hodges wrote:
> Hello,
> I am trying to build grass 5.4.0 on Mandrake 10.0 CE. I have one problem left.
> I  receive the following errors from build:
> Compilation error in module: src/libes/dbmi/lib
There is probably one error here that has caused all the others.
> There are no problems in compile. If I check make.log these errors are all
> caused by an undefined reference to db_malloc. Can anyone help me figure out
> which library I am missing or have the wrong version of installed.
Not a lot to go on there unless someone is very familiar with the dbmi
library. Can you post the actual error message (output from make)?
Paul K
