[GRASSLIST:5758] Re: g.mlist problem
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Mon Feb 14 11:27:22 EST 2005
thanks, now it's working with "mapset=PERMANENT", Martin
On Thursday 10 February 2005 15:43, Huidae Cho wrote:
> Hi,
> That is a kind of bug. You should specify a mapset which contains
> a00.*img maps. g.mlist does not search the mapset search path that
> g.list uses, so I fixed it in CVS.
> Try something like this:
> g.mlist pattern='a00*.img' mapset=PERMANENT
> Huidae Cho
> On Thu, Feb 10, 2005 at 01:32:33PM -0500, Martin Wegmann wrote:
> > hello,
> > I want to list all raster files which start with a00, but I did not
> > receive any output when using this command:
> > g.mlist pattern="a00*.img"
> > or just "a*" does not result in any file listing.
> > however g.list rast gives me:
> > a00011nd.img a84102nd.img
> > a00012nd.img a84103nd.img
> > a00013nd.img a84111nd.img
> > a00021nd.img a84112nd.img
> > How do I use g.mlist properly? Martin
Dipl.-Biol. Martin Wegmann
DLR - German Aerospace Center
German Remote Sensing Data Center
Dept.of Geography
Remote Sensing and Biodiversity Unit
University of Wuerzburg
Am Hubland
97074 Würzburg
phone: +49-(0)931 - 888 4797
fax: +49-(0)931 - 888 4961
http://www.biota-africa.org
http://www.biogis.de
