[GRASSLIST:5720] Re: g.mlist problem
Huidae Cho grass4u at gmail.com
Thu Feb 10 15:43:30 EST 2005
That is a kind of bug. You should specify a mapset which contains
a00.*img maps. g.mlist does not search the mapset search path that
g.list uses, so I fixed it in CVS.
Try something like this:
	g.mlist pattern='a00*.img' mapset=PERMANENT
Huidae Cho
On Thu, Feb 10, 2005 at 01:32:33PM -0500, Martin Wegmann wrote:
> hello,
> I want to list all raster files which start with a00, but I did not receive
> any output when using this command:
> g.mlist pattern="a00*.img"
> or just "a*" does not result in any file listing.
> however g.list rast gives me:
> a00011nd.img  a84102nd.img
> a00012nd.img  a84103nd.img
> a00013nd.img  a84111nd.img
> a00021nd.img  a84112nd.img
> How do I use g.mlist properly? Martin
