[GRASSLIST:5766] Re: errors on 5.4.0 build
Maciek Sieczka werchowyna at pf.pl
Mon Feb 14 13:24:53 EST 2005
Kent
What gcc are you using? I'm asking because I had almost identical errors
with gcc 3.4.1 on Mandrake 10.1. See
http://grass.itc.it/pipermail/grass5/2005-January/017014.html. After
switching to 3.3.4 all went fine (though no idea why).
Maciek
> Hello,
> I am trying to build grass 5.4.0 on Mandrake 10.0 CE. I have one problem
> left.
> I  receive the following errors from build:
> Compilation error in module: src/libes/dbmi/lib
> Compilation error in module: src/libes/dbmi/clients
> Compilation error in module: src/display/d.db
> Compilation error in module: src/display/d.what.db
> Compilation error in module: src/display/d.what.vect
> Compilation error in module: src/mapdev/v.db.reclass
> Compilation error in module: src/mapdev/v.out.shape
> Compilation error in module: src/mapdev/v.to.db
> Compilation error in module: src.contrib/SDTS
> Compilation error in module: src/libes/dbmi/drivers/odbc
> There are no problems in compile. If I check make.log these errors are all
> caused by an undefined reference to db_malloc. Can anyone help me figure
> out
> which library I am missing or have the wrong version of installed.
> Kent Hodges
