[GRASSLIST:5768] Re: errors on 5.4.0 build
Kent Hodges
hodgesk at eastlink.ca
Mon Feb 14 15:05:17 EST 2005
Thanks Maciek,
I was running gcc 3.4.1. I changed to 3.3.4 and it built without errors.
Kent
On February 14, 2005 02:24 pm, Maciek Sieczka wrote:
> Kent
> What gcc are you using? I'm asking because I had almost identical errors
> with gcc 3.4.1 on Mandrake 10.1. See
> http://grass.itc.it/pipermail/grass5/2005-January/017014.html. After
> switching to 3.3.4 all went fine (though no idea why).
> Maciek
> From: "Kent Hodges" <hodgesk at eastlink.ca>
> > Hello,
> > I am trying to build grass 5.4.0 on Mandrake 10.0 CE. I have one problem
> > left.
> > I receive the following errors from build:
> > Compilation error in module: src/libes/dbmi/lib
> > Compilation error in module: src/libes/dbmi/clients
> > Compilation error in module: src/display/d.db
> > Compilation error in module: src/display/d.what.db
> > Compilation error in module: src/display/d.what.vect
> > Compilation error in module: src/mapdev/v.db.reclass
> > Compilation error in module: src/mapdev/v.out.shape
> > Compilation error in module: src/mapdev/v.to.db
> > Compilation error in module: src.contrib/SDTS
> > Compilation error in module: src/libes/dbmi/drivers/odbc
> > There are no problems in compile. If I check make.log these errors are
> > all caused by an undefined reference to db_malloc. Can anyone help me
> > figure out
> > which library I am missing or have the wrong version of installed.
> > Kent Hodges
