[GRASSLIST:5806] Re: v.in.e00 import error
    Giacomo Bertoldi
    giacomo.bertoldi at ing.unitn.it
    Wed Feb 16 10:24:13 EST 2005
Thanks for you help.
I've bypassed the problem moving back to grass5.4 m.in.e00
Giacomo
On 16 Feb 2005, at 3:13 PM, Lorenzo Moretti wrote:
> Hi Moritz
>> On Wed, February 16, 2005 11:29, Lorenzo Moretti said:
>>>  Now I have recompiled from source these 2 software (avcimport and
>>>  e00conv) and I have tested them.
>>>  I have converted my e00 before with this command:
>>>  % avcimport  /myfilepoint.e00 /coverage
>>>  it creates 2 folder:
>>>  coverage with 6 .adf files inside: bnd lab pat prj tic tol;
>>>  info with 7 files inside: arc.dir arc0000.dat arc0000.nit
>>> arc0001.dat
>>>  arc0001.nit arc0002.dat arc000.nit.
>> Could you check the file size of the resulting files ? In my case,
>> they are
>> always much smaller then they should be (a few kb for a map which in
>> e00
>> format is several tens of MB). This seems to mean that they are not
>> converted
>> correctly which would explain the problem for v.in.ogr.
>> Moritz
> The size of export file is OK for me.
> Example:
> original file1.e00 (65 MB)
> with avcimport I have:
> file1 (folder size about 30 MB with many layers inside)
> info (folder size about 0.1 MB)
> Is ogr the problem?
> This file would be an Arc/Info coverage with layers and data but if I
> use ogrinfo I have:
> Unable to open datasource
> Who can help us?
> _______________________________________________________________________
> _
> ||      Lorenzo Moretti        e-mail: lorenzo.moretti at bologna.enea.it
>     ||/|/|  ENEA prot/idr          Web: http://wwwamb.bologna.enea.it/
>    ||   |  via Don Fiammelli, 2   FTP: ftp://ftpamb.bologna.enea.it/
> (ris.)
> ~~~~~~  40128 BOLOGNA - ITALY  Ph: +39-0516098086  Fax: +39-0516098131
> _
   Giacomo Bertoldi, Ph.D.
   Dept. of Civil and Environmental Engineering
   University of Trento - ITALY
   E-MAIL:    giacomo.bertoldi at ing.unitn.it
   PHONE:   +39 0461 882610
   FAX:          +39 0461 882672
