[GRASSLIST:5803] Re: v.in.e00 import error
Lorenzo Moretti lorenzo.moretti at bologna.enea.it
Wed Feb 16 09:13:05 EST 2005
Hi Moritz
>On Wed, February 16, 2005 11:29, Lorenzo Moretti said:
>>  Now I have recompiled from source these 2 software (avcimport and
>>  e00conv) and I have tested them.
>>  I have converted my e00 before with this command:
>>  % avcimport  /myfilepoint.e00 /coverage
>>  it creates 2 folder:
>>  coverage with 6 .adf files inside: bnd lab pat prj tic tol;
>>  info with 7 files inside: arc.dir arc0000.dat arc0000.nit arc0001.dat
>>  arc0001.nit arc0002.dat arc000.nit.
>Could you check the file size of the resulting files ? In my case, they are
>always much smaller then they should be (a few kb for a map which in e00
>format is several tens of MB). This seems to mean that they are not converted
>correctly which would explain the problem for v.in.ogr.
>Moritz
The size of export file is OK for me.
Example:
original file1.e00 (65 MB)
with avcimport I have:
file1 (folder size about 30 MB with many layers inside)
info (folder size about 0.1 MB)
Is ogr the problem?
This file would be an Arc/Info coverage with layers and data but if I
use ogrinfo I have:
Unable to open datasource
Who can help us?
________________________________________________________________________
||      Lorenzo Moretti        e-mail: lorenzo.moretti at bologna.enea.it
||/|/|  ENEA prot/idr          Web: http://wwwamb.bologna.enea.it/
||   |  via Don Fiammelli, 2   FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~  40128 BOLOGNA - ITALY  Ph: +39-0516098086  Fax: +39-0516098131
