[GRASSLIST:5800] Re: v.in.e00 import error
    Moritz Lennert
    mlennert at club.worldonline.be
    Wed Feb 16 05:55:55 EST 2005
On Wed, February 16, 2005 11:29, Lorenzo Moretti said:
> Now I have recompiled from source these 2 software (avcimport and
> e00conv) and I have tested them.
> I have converted my e00 before with this command:
> % avcimport  /myfilepoint.e00 /coverage
> it creates 2 folder:
> coverage with 6 .adf files inside: bnd lab pat prj tic tol;
> info with 7 files inside: arc.dir arc0000.dat arc0000.nit arc0001.dat
> arc0001.nit arc0002.dat arc000.nit.
Could you check the file size of the resulting files ? In my case, they are
always much smaller then they should be (a few kb for a map which in e00
format is several tens of MB). This seems to mean that they are not converted
correctly which would explain the problem for v.in.ogr.
Moritz
