[GRASSLIST:5814] Re: v.in.e00 import (resolved in OSX)
Lorenzo Moretti lorenzo.moretti at bologna.enea.it
Wed Feb 16 15:09:55 EST 2005
Hi all
After some changes I've built OSX bin of avcimport and e00conv. You
can download the zip file (460 kb) for testing at:
http://wwwamb.bologna.enea.it/forgrass/files/avce00_osx.zip
AVCE00 for OSX version 1.2.0
Official site: http://avce00.maptools.org/
6 binaries:
   avcdelete
   avcexport
   avcimport
   avctest
   e00conv
   ex_avcwrite
e00conv uncompress an e00 compressed file.
avcimport converts e00 files to Arc/info coverage and the new file
created can be imported in Grass with v.in.e00 or v.in.ogr.
Install
put 6 bin inside bin folder of grass60 and grass60cvs or wherewere
you want to use. Example in Grass:
   grass60cvs.app/Contents/Resources/grass-6.0.cvs/bin
Use
Now it's possible to use v.in.e00 in Grass 6.
In GIS Manager select File->Import->Vector map->ESRI e00 format
In the window select your E00 file (ex. myfile.e00), the input type
(ex. point) and the name of new vector (ex. point_from_e00). Press
Run and you have imported your e00 file.
v.in.e00 is not complete and it's possible to have errors.
You have more controls via terminal for input type and layers
In grass terminal enter (example):
% avcimport /e00files/myfile.e00 /e00files/mynewcoverage
% v.in.ogr -o dsn=/e00files/mynewcoverage/ layer=LAB type=point
output=point_from_e00
More info at official site.
Info about v.in.ogr inside help docs.
Bye
________________________________________________________________________
||      Lorenzo Moretti        e-mail: lorenzo.moretti at bologna.enea.it
||/|/|  ENEA prot/idr          Web: http://wwwamb.bologna.enea.it/
||   |  via Don Fiammelli, 2   FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~  40128 BOLOGNA - ITALY  Ph: +39-0516098086  Fax: +39-0516098131
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050216/eda28023/attachment.html
