[GRASSLIST:5867] Re: Problem installing grass-6.0.0beta2
David Adam
david at quercus.org
Mon Feb 21 12:20:44 EST 2005
Stephan Holl wrote:
>Hello David,
>On Mon, 21 Feb 2005 07:24:22 -0800 David Adam <david at quercus.org> wrote:
>>*The* **libgdal.so.1 *file does exist, at /usr/local/lib/libgdal.so.1,
>>so I apparently need
>>to modify a search path somewhere, but cannot find anything in the
>>docs. Can anyone
>>help me out? TIA
>you need to add the path /usr/local/lib
>to /etc/ld.so.conf
>and run
>ldconfig
>afterwards.
>This should solve the problem of not finding the lib.
>hth
> Stephan
Worked like a charm! Many thanks!
david
