[GRASSLIST:5905] Re: s.in.ascii -replacement?
Hamish
hamish_nospam at yahoo.com
Thu Feb 24 16:46:00 EST 2005
> I just upgraded to Grass 6.0.0beta2, and found out, that I have a
> large problem. Earlier, I used to keep my data in plain text files in
> the form:
> 10:34:23.23E 45:12:00.23N 0 "What a dump!"
> In Grass 5.0, this type of data was easily imported through
> s.in.ascii, but in the curretn version, s.in.ascii does not exist any
> more, and v.in.ascii is not capable of reading files of this type. Is
> there any way importing these files is possible, or do I have to
> manually convert all of the data?
v.in.ascii is the module to use, but currently it does not support
DDD:MM:SS format for import coordinates (GRASS wish #2993).
For now Lat/lon coordinates must be given in decimal degrees.
e.g.
10.573112,45.200064,0,What a dump!
v.in.ascii fs=',' ...
I don't know if quoting text helps or if you need to use another
deliminator.
Hamish
